olio differenziale posteriore
I vari produttori di oli devono riportare le specifiche approvate dai vari costruttori di autovetture,se non le trovi lascia perdere.
Al massimo vai in MB
- silti
Questo è quello che dice MB sull'olio per il differenziale235.62 Differential gear oils (Specification 235.62)
The following product list should help you to select the correct operating fluid for your vehicle/major assembly from the variety of products in the market.
We are recommending to use exclusively the products listed in the following overview, because only these products have been tested and approved by Mercedes-Benz.
We recommend using only products
1.which are distinctly marked with the label indicating the approval of Mercedes-Benz, e.g. “MB-Approval 229.51”. Labels referring e.g. to “MB 229.51” don't have an approval of Mercedes-Benz.
2.Which are listed in the current MB BeVo. Only listed products are tested and approved by Mercedes-Benz.
Application in vehicles/major assemblies refer to Sheet 231.1 Type 156, 176, 246 with Code (4matic)
Overview Search Results
Last update: 09/04/2014
PRODUCTNAME PRINCIPAL
Mercedes-Benz Hinterachsgetriebeöl MB 235.62 Daimler AG, Stuttgart/Deutschland
MB 235.62 Hinterachsgetriebeöl A 002 989 02 03 Daimler AG, Stuttgart/Deutschland
Lo scarico è proprio sotto,il rabbocco non lo so
