Ecco la loro ultima Email, credo che a breve lo comprerò.
Hi,
Shipping to Italy will be made my USPS mail and we have different options. I would strongly recommend USPS Priority International Mail as it will provide you tracking information and will arrive more quicker. Cost is usually around $40 USA.
You can add all of the items you need to the shopping cart on the website and it should give you shipping quotes after you put in your address.
I have confirmed with the engineers at Crux that the informatio below is accurate. I even had them update their product manual. See attached.
At the bottom of the page I have added in the section labeled "Compatibility Notes". Because i updated the info, you may need to clear your browser cache/history. It reads:
Compatibility Notes:
Compatible with NTG5.1 Command Radio Systems
Compatible with Audio 20 Systems IF the vehicles production date is December 2015 or later. If the vehicles production date is November 2015 or earlier, then the vehicle will need to be brought to the dealership prior to adding CarPlay functionality with the CAPMB-51.
On Feb 17, 2017 2:10 AM, "J. A" wrote:
Although I read all the description I didn’t find nothing about Audio 20 System, I’m sure that my car was produced later than December 2015 but I don’t have the Comand. I want to be sure that will not be problem with installation.
Another question is the shipment and customs. How much the shipment to Italy? How many days to arrive?
I will pay with paypal.
Audio 20
- Miangu
- Auto guidata: BMW 120d Xdrive Msport
Ciao a tutti!
Se non capisco male questo oggettino in pratica "inietta" via presa diagnosi OBD una specie di virus che sblocca le funzionalità di interfaccia carplay o AndroidAuto e poi si rimuove. Quindi non ci sono cavetti o componenti aggiuntivi.
Al di là della "legalitá" o meno della cosa.., ma perchè non dovrebbe essere possibile (anche a pagamento s'intende) via rete ufficiale MB? Mi sono perso qualche passaggio?
Lunga vita e prosperità!!
- theBugger
Non viene installato niente, anche perché non sarebbe possibile. Viene abilitato allo stesso modo di come farebbe lo StarDiagnosis.
La rete ufficiale non lo fa perché probabilmente la casa non lo prevede
A180 CDI 1.5l Manuale 2015
[Guy Martin]
[Guy Martin]
- Miangu
Ciao grazie per la risposta.theBugger ha scritto:Non viene installato niente, anche perché non sarebbe possibile. Viene abilitato allo stesso modo di come farebbe lo StarDiagnosis.
In questo caso, se la politica MB non cambierà, onestamente la tentazione di usare lo scatolino è forte.
Chi vivrà.. vivrà (come direbbe Paolo Bitta.. ) !
- Raymun
- Auto guidata: W176 Classe A 180d Premium automatica
Avevo avuto anche io lo stesso problema, se non ricordo male avevo risolto inserendo immagini in formato PNG, con dimensioni di 250x250pxandrean ha scritto:Help.....
Non riesco ad inserire l'immagine nei file mp3 ,o meglio ..come procedimento uso quello suggerito qua,cioè uso Il programmino Mp3 Tag, il procedimento è corretto ,ma io continuo a non visualizzare la cover nella 180....
Ho anche rispettato il consiglio di non superare i 60kb e 500x500 ma niente....
Mi potete aiutare a capire il perché?
Grazie anticipatamente...
P.s sul pc con iTunes,WMP comunque si vedono...ma quando provo sull'audio 20 non si vedono.....
Mercedes-Benz Classe A - W176 MY807 - 180d Premium Automatic
Bianco Calcite - Cerchi AMG Black Performance 18" - Mirror Package - Pacchetto Night - Telecamera Posteriore - Display da 8" - Carplay
Coprimozzo Neri - Stemmi Frontale & Posteriore Neri - Minigonne Nere - Bulloni Antifurto
- AleMB
Ci sono delle cose che nemmeno lo StarDiagnosis permette di fare, per questo a volte "si è obbligati" ad orientarsi verso moduili aggiuntivi!theBugger ha scritto: Viene abilitato allo stesso modo di come farebbe lo StarDiagnosis.
Alessandro
- theBugger
In questo caso non è così. Un dispositivo che viene connesso solo per "attivare" e "disattivare" una funzione sfrutta un'opzione prevista in fase di progettazione, altrimenti appena rimosso verrebbe persa la funzione. Inoltre se così non fosse significherebbe che l'"aggeggio" stesso dovrebbe gestire il mirroring e comandare il display (tecnicamente impossibile).AleMB ha scritto:Ci sono delle cose che nemmeno lo StarDiagnosis permette di fare, per questo a volte "si è obbligati" ad orientarsi verso moduili aggiuntivi!theBugger ha scritto: Viene abilitato allo stesso modo di come farebbe lo StarDiagnosis.
Il fatto che la casa non preveda qualcosa tramite SD non significa che sia "fisicamente" assente. Per farti capire pensa che lo SD è solo un'interfaccia che usano i tecnici sul campo (officine) per configurare le auto. E' probabile che esistano diverse versioni dello stesso che permettono diversi livelli di accesso e di possibilità di intervento
[Guy Martin]
[Guy Martin]
- AleMB
In questo caso no... Ma in tanti altri.... Come disattivazione S&S, sblocco VIM, chiusura vetri da telecomando, ecc.........
Alessandro
- theBugger
Tutte funzioni non previste dalla casaAleMB ha scritto:In questo caso no... Ma in tanti altri.... Come disattivazione S&S, sblocco VIM, chiusura vetri da telecomando, ecc.........
[Guy Martin]
[Guy Martin]
Lo stardiagnosis potrebbe fare molte più cose se non fosse "blindato" da MB
- AleMB
Bè ovvio, però su altri marchi con la diagnosi sblocchi tutto quello che può fare la macchina.....theBugger ha scritto:Tutte funzioni non previste dalla casa
Startaxi ha scritto:Lo stardiagnosis potrebbe fare molte più cose se non fosse "blindato" da MB
Alessandro
- Auto guidata: Mercedes W205 220d Coupè
Sono responsabile dell'aggiornamento del loro manuale...
Credo che a breve lo prenderò, c'è qualcuno che la prende con me?
Quando si pattina su ghiaccio sottile, la salvezza sta nella velocità
Ralph Waldo Emerson
Ralph Waldo Emerson
